Re: wow..gimmyjimmy needs help!
Don Ohio /
Block the so-called injection(disable and disconnect the pump), mix 40:1, and replace that spark plug, also making sure the carb is releasing the choke fully and there is no thru-leakage of fuel thru the needle valve. ALL that said and DONE?..........you got a perfect `ped! LOL! Take care GJ! don-ohio
