no spark
Mike Kondracki /
My 1980 Sachs has no spark. The tail light also lights up when I pedal, is this normal? Any suggestions on the problem? Everything looks to be in working order. It is my first moped, so any help will be appreciated.
Re: no spark
Ben Van Zoest /
Goto RESOURCES Fred explains why...
Re: no spark
Also,replace the spark plug at the first hint of spark trouble. Clean and gap the points to .016" inches,not mms. Make sure kill switch(on-off) isn't grounding the ignition wire that comes off the magneto. don-ohio
Re: no spark
Mike Kondracki /
tried everything but still no spark. my cousin thinks its my coil, how do i test that? which wire is my ignition wire from the magneto?
Re: no spark
probably not the coil... Does it have a condenser? I have seen these many times go out.
Alan
Re: no spark
Disconnect your kill switch wire from engine side first and check for spark.
Check points if they open and clean.
Z
Re: no spark
Mike Kondracki /
tried disconnecting wire, but alas nothing. i just can't figure this thing out. how do i tell if the condenser or the coil is bad? how do i know if my points are any good? thanks for the help
