busted trhead
i have a puch maxi with one of the cylinder threads busted, has anyone ever had this problem and if so what did you do about it. i think i might try to helicoil it but im not sure how that would work so i considered puttin larger threads in there for bigger bolts because im planning on modding the engine quite a bit so i want the strength.
Re: busted trhead
Gregory Mcintire /
I think that generally a helicoil, done properly, is stronger than the original. If you put in a larger stud you may run into problems with fitting the cylinder and head without drilling them also.
Re: busted trhead
Scott Joyce /
thanks for the info
Re: busted trhead
Jason Luther /
if you put two nuts on the bolt, you can just turn it out and replace it with another one, that is , unless ofcourse, its broken off at the engine case. i cant see any reason to put bigger studs in there.-jason
Re: busted trhead
i'm a toolmaker and helicoil is def. the best way to go... like scott said IF it's done right.
Re: busted trhead
whats a helicoil?
Re: busted trhead
I think it a the shape of DNA or something!!
Re: busted trhead
Jason Luther /
but why not just unscrew the old stud and put in a new one? a million times easier.-jason
Re: busted trhead
to amory... it's not the stud its the hole. to guywaters... a helicoil is a coil of spring steel that takes the shape of the orig. thread after the hole has been drilled and tapped slightly larger than orig. and to banjerbob the shape of dna is a double helix. PEACE
Re: busted trhead
Scott Joyce /
yah i wish the prob was as easy as putting in a new bolt but its the threads in the engine block that broke so i have ot helicoil them.
Re: busted trhead
Jason Luther /
okay, then disregard everything i said before dr crick.-jason
