Re: backfires from air intake
Gregory Mcintire /
Another thing other than timing that can cause backfiring is having loose connections in the ignition circuit. This includes every wire from the points/condenser to the HT coil including the kill switch wiring. A loose wire can have the same affect as the points opening, and thus firing the spark at the wrong time.
