Re: Oily exhaust pipe...
Ben Jammin /
An oily pipe is very common as not all the oil get burned. Stay with a 50:1 mix. You should clean your pipe. Carbon and oil build up in your exaust pipe will cause performance problems. I have had many mopeds not run well because of to much pressure build up in the pipe due to a clogged pipe. You should most definately clean your carb and pipe and after you do then adjust your idle screw.
