1978 J.C Penney pinto2
Engine will not fire. coil checks ,new points installed ,new plug , new condenser. What now ?
Re: 1978 J.C Penney pinto2
Leon Swarmer /
Can you see the spark with the plug out of the cylinder?
timing?
are you sure fuel is getting into the cylinder?
Leon
Jake Van Order /
the puch electrical system is a tricky thing. there are times that I can't get it to work no matter what. I guess my best suggestion is to go over the wiring again. even the horn disconnected will cause it not to spark. good luck
--jake
Jake is right, check the two wires that go in the back of the horn. Probably a brown and a blue or black. Both have to be connected.
Go over the bike and make sure all the Brown wires are properly grounded
Thanks for the advice regarding the Pinto. The fact that I do not have a horn may account for my problem. Will connect the horn wire together and give it a try. Thanks again if it works or not.
