1978 PA50II won't spark!
Keith Cunningham /
Hey everyone, I have a 1978 PA50II that I have rebuilt and everything seems ready to go but I cannot get it to spark for the life of me! And when I say everything, I mean everything:
-Corrected timing .3mm
-Tried 2 different condensers
-Recut the condenser cable
-Cleaned the points
-Yes the key is in and turned and the knob thing is set to run
-TDC is correct
-The spark gap is correct .6mm
-To the best of my knowledge the wiring is all correct (If anyone has a wiring diagram for a US Hobbit II it would be much appreciated.)
-The headlight and taillight work so obviously its getting power somewhere and some of the wiring is correct.
Does anyone else have another suggestion before I bring this thing to the local scooter shop? I swear I have it all correct but its driving me crazy!
Thanks
-Keith
Re: 1978 PA50II won't spark!
No Spark could also be a malfunctioning kill switch. The two wires leading to the switch must not touch each other or the frame.
Bypass ALL the switches and frame wiring by connecting the black/(yellow?) wire coming out of the engine directly to the black/white wire that goes back to the ignition coil.
If you then get spark, your wiring is messed up somewhere on the frame.. Might be some worn insulation that shorts a wire. Might be anything.. (Wires under the rear fender tend to get pounded by rocks are are often in terrible shape)
A manual for the 1983 PA50 Hobbit is here.. Good info that applies to the 1978 but the electrical diagrams don’t match up ..
http://www.mopedriders.org/article_cat.php?fldAuto=2&sid=5a2cab5705ffec7757b4538cafc5ba61
Heres a proper electrical diagram..
https://www.mopedarmy.com/forums/discuss/download.php?f=6&file=1082480832_honda_pa50_1978_wiring_diagram.jpg
ಠ_ಠ Jon Folks ಠ_ಠ /
I would also try various plugs too. I had a bike with like 2 like new looking plugs on it, both had burnt out.
Jon
Keith Cunningham /
Holy crap Joew, you are the friggin man! I cannot believe it. I have been trying so hard just to get a spark and that helps to bring me so much hope. I went in there, unplugged everything, plugged black to black/yellow and with some pedaling it was sparking like a mad man. You are the friggin man. And with the wiring diagram, jesus you are the man! Thanks so much!
-Keith
glad it helped.. a mixture of pure luck plus days of dicking with the exact same problems on the exact same bike.
I didn't have the wiring diagram for a long time. Someone else in here turned me on to it.
