Califfo questions
Dustin Cutt /
Hello guys, I have looked back at all the old posts on Califfo mopeds but none have answered my questions.
1]What is the fuel mix? I have heard many different mixes used on califfos, all the way up to 14:1!!
2]What is the correct level of oil in the oil sump,[only other califfo owners would know]
3] what is the stock High/Low screw set at on the Dellorto[so I have a base to go from.
Oh a history on the moped, I bought it at an automotive fleamarket, running, for 150.00 it needs work but hell I cant go wrong. It has a good blue spark so atleast I don't have to fight with the points.!! Oh and are there any other mopeds similar to a califfo? for a possible engine swap?
Re: Califfo questions
Dustin Cutt /
60hp OP
no answers?
if you don't know the oil mix, use a safe amount, like 24/1 until you find out.
the correct oil level on most engines is when it overflows out of a bolt hole somewhere near 1/2 way up the case.. sometimes that same hole is also the filler hole.
i dunno squat about dellortos..
nice deal.. $150 for a running bike is very cool.. no idea wtf a Califfo is so can't help you on similar makes.
Hang in here for a couple weeks and search for info on your own. You will become the resident Califfo Expert.
http://www.mopedriders.org/article_view.php?faq=2&fldAuto=14
Here's a manual. Also contact Devin of Motion Left. He's got a Califfo and it's tuned to the max.
BK
Dustin Cutt /
60hp OP
thanks man....
