peugeot 103 - parts sources?
looking for carb kit, all seals, wheel bearings, brake pads..
Re: peugeot 103 - parts sources?
Matthew Barnes /
Mopedwarehouse.com has carbs and some parts for the carb as well as brake pads. Not sure on the bearings. A few gaskets listed.
Good Luck.
Wheel bearings can be aquired from a Bearings shop, probbably in your own town, somewhere. ask around at machine shops and the like. Of course, you'll need an example of the old bearings.
I doubt you actually need new brake pads, unless you need the whole assembly. I've seen worn down brake pads, but they still work. I've never seen pads worn all the way through..
