Motobecane 40T - When I give it gas it stalls out.
Can anyone help me on this one. I have a 70-71 Motobecane 40. It was running nicely last night for a couple hours and then all of a sudden when I excellrate it just started to bog down on me and stalls out. Now I can get it started. It sounds like it wants to start but something is holding it back.
I have put a new compressor on it.
The carborator is clean.
The fuel mixture is correct.
What can it be. Can someone help me on this??
Thank you for your time
Re: Motobecane 40T - When I give it gas it stalls
did you clean the carb after the problem started? It sounds like you may have thrown a clot(of rust) and it clogged up a jet.
IS IT OUT OF GAS??????
ಠ_ಠ Jon Folks ಠ_ಠ /
Check to make sure it not getting too much air(or not enough) Upjet?
Brooklyn
_"Check to make sure it not getting too much air(or not enough) Upjet?
Brooklyn_"
Will upjetting cure 'too much air' and 'not enough air'?
No, it will only cure "too much air". But that is also curable by holding the choke in or putting a thumb over the air intake.
Bring the bike to me brotha...we'll clean that gas tank out.
