vespa piago boxer fork lock
Edwin Johnson /
I am trying to turn the lock ..anyone out there who has a working lock..which way to turn to move lock in and out...???
1974 piaggo ciao boxer 2
Re: vespa piago boxer fork lock
lets see.. you have two choices. Left or Right.
..or is there more to your question than meets the eye..
Bruce Wilkinson /
Can you post a picture of your Ciao Bower 2. Is it different from a Ciao. bruce
Edwin Johnson /
My lock is stuck in vertical position... I asked which way to turn to try and avoid breaking the key off or jamming it up...
Leon Swarmer /
Have you tried moving the fork back a forth a bit as you try and move the key?? You probably have, but I thought I'd ask.
Make sure you have the right key.. Not the ignition key and Not the helmet lock key if there is one.
if you're sure you have the right key, spray some WD40 or lock lube in there..
