OPEN A MOTOBECANE CLUTCH?
Hello, moped boys and girls. I need some help!
I've got a 1980 motobecane "le moped" and I'm trying
to get the clutch apart to do a little work but it's not happening. I've tried using a puller but it didn't work.
Before I go cranking on it, assuming the real problem is that it's just corroded as hell, I want to make sure I don't need some obscure and special tool to open this thing up.
Anyone been through this?
Thanks!
-K
Re: OPEN A MOTOBECANE CLUTCH?
See Ya Moped Army /
You need a Motobecane clutch puller tool to remove the clutch. If you try to use a generic puller, you may end up causing damage.
I just found one online after I posted.
Thanks a million, mopedlar!
-K
