Re: Tomos
Bill Sparling /
I recently had a similar problem. Once the dead gasket finally blew we had the answer. In my case, the cylinder head bolts had vibrated loose barely enough to compromise compression, eventully this caused the head gasket to let go entirely. The fix: torque the bolts to spec and locktight them. Then make checking the torque part of your regular planned maintenance routine.
