Puch - Tranny cover leak
Anyone have any good ideas how to stop a tranny from leaking fluid. I replaced the gasket but it still leaks. It is leaking at the bottom screw on the actual tranny cover (not the drain plug)?
Any ideas!?
Thanks
Re: Puch - Tranny cover leak
Jason Luther /
is there a hairline crack?
I took the whole cover off before I replace the gasket and I did not notice anything. It might be that the cover is nicked up a enough that the gasket does not create a seal maybe?
It could be that the gasket is offset slightly, resulting in a leak.
are you sure its not being caused by laying the moped on it's side? When I lay my puch on its side the trans fluid leaks out....
-rand
Jason Luther /
if it pursists just get some rtv sealant and make your own new gasket. $0.99 for a small tube.-jason
