Re: Batavus HS50 Clutch not disengaging
Josh Latour /
Hi again,
Thanks for responding,
No The clutch lever cable is not binding. The Lever cable return spring does its job and pulls the clutch lever arm off the clutch. It is just the clutch itself that is not releasing. The lever cable and clutch lever arm all work fine. To clarify; the clutch does not disengage, even when I manually operate the lever arm at the engine case. Thanks for inquiring though...... Any other suggestions??
Josh
