Re: Batavus HS50 Clutch not disengaging
Joe Woods /
Is the start-lever-clutch cable binding? Maybe the lever return spring is weak or broken or attached at the wrong place?
Does the clutch always disengage when you manually move the clutch lever at the engine case?
