Re: Where Should I Fill My Trans To? (Tomos)
Paul Joynes /
There is a phillips head screw approximately 1/4 of the way up on the right hand side of the crank case. Remove this screw (you will know it is the correct one because it will have a copper washer). When the ATF fluid starts to come out this hole you know that the crank case has the propper amount in it.
Drongo
