Where Should I Fill My Trans To? (Tomos)
Deon Holland /
My friend has a 00 Tomos Targa. When he drains and refills his trans fluid, where should he fill it up to? How do we know if it's full?
Re: Where Should I Fill My Trans To? (Tomos)
There is a phillips head screw approximately 1/4 of the way up on the right hand side of the crank case. Remove this screw (you will know it is the correct one because it will have a copper washer). When the ATF fluid starts to come out this hole you know that the crank case has the propper amount in it.
Drongo
Also, before screwing in that screw again, make sure the ATF stops coming out first.
