Re: Fuel Flow
Leon Swarmer /
Andy, My garelli had a circular shaped fuel filter built on the carb right where the fuel line goes in. Do you have one? Have you cleaned this?
yes the 30 is the same 30
No decompression valve on my Eureka Flex
did you thoroughly clean the side where the gaskets meet?
you probably did.. you mibht need to put a straightedge against it to see if something is warped maybe???
