Re: moped runs by itself!
Matthew Coles /
You have an air leak, that's what's causing the accelerating idle. Hold the throttle at a steady speed while it's on the stand and spray carb cleaner around the carb, intake, and cylinder (where the gaskets are)...if your engine dies when you spray a certain spot, there's your leak.
