Re: Replaced gaskets galore, still won't start (Pu
Matthew Coles /
If you have spark, and you're getting fuel, you're either lacking sufficient compression (doubtful), or your timing / points are off. Has anyone messed with the flywheel or the points? I installed the stator plate and then flywheel on my Puch, but it wouldn't run until I had the stator plate set in the correct spot and the points set properly.
