Puch maxi 76' points
I would like a diagram of where the points are on my puch maxi.
Re: Puch maxi 76' points
Mike Monigold /
There is a cover over the magneto on the side of the engine. If you take that off you'll find a metal hub with slots in it. If you rotate that hub by hand and look through the slots you'll see the points under it. You can adjust the points through that slot. However, you will have to remove the hub if you need to replace them.
Jason Luther /
thay are at about the 10 oclock position and look like two pencil erasers clicking against each other (except not rubber, nor do they say ticonderonga)-jason
