alternative checking gear oil
Leon Swarmer /
HI all,
On my 75 Graelli Eureka flex. the oil check bolt is gone and the Previous Owner filled the hole with some type of silicon caulk(??). Is thre an alternative way to chekc the oil or do I dig it out, check it, check the hoels for messed up threads and caulk it up again.
Leon
Re: alternative checking gear oil
John Joedicke /
Drill and tap the old hole and use a brass pipe plug.Silicon is pretty getto when you are working with nuts and bolts etc.
