I need help with my puch maxi 76'
The problem is that it wont Idle I have to give it gas right away and keep it going of else it stalls Plz help me
Re: I need help with my puch maxi 76'
Jason Luther /
first of all is your throttle cable at the right adjustment, and then is your idle screw set properly (it wont work at all if the cable is too far out of wack). if those are okay check for air leaks. i just found that the intake manifold, where it connects to the cylinder was warped so i had to grind it flat. than if no leaks id check your timing. my points have a tendency to close a little periodically which wont let me idle, it also diminishes top speed quite a bit.-jason
