Help with Puch oil inject
Keith Cunningham /
Hello everyone, haven't posted in a while but I was working with AntiKontrol today on fixing some peds and we came across an oil injected Puch Magnum. It starts but oil comes spewing out the exhaust. Like I mean you hold your hand over it and hot oil sprays all over your hand. Well I think its due to the oil injection on this model (unless someone else has a better suggestion) So I removed the whole injection section but the motor is now like swiss cheese. I was wondering how you guys usually convert the oil injected systems to a pre-mix one. Here are some pics of what I am talking about. Hopefully someone has done this already and can help me. Thanks
-Keith
www.surfacerustbrigade.com
Re: Help with Puch oil inject
Keith Cunningham /
There is a hole in the motor cast and one in the intake. Let me know if you got a solution.
-Keith
keith, i did this the same to mine awhile back. get a piece of aluminum, and cut it to that size,drill a hole on each end to fasten it and silicone/glue it in place.
you can then run premix........i never had a problem again with it.
the magum oil injection was known for running on the very rich side.
Keith Cunningham /
Hey thanks Paul! Thats all I was hoping it was. What did you do about the intake manifold? Did that have to be modified at all? Mine has a little nipple on it . Thanks
-Keith
