Re: runs then dies, the runs??
D Nyberg /
Odd. 1/2 hour, you say?
Is the pinhole vent on the gas tank clear? If it's become clogged, the tank can develop a vacuum as gas is used, and fuel flow will slow down. It might be equalizing pressure during the time you're fooling around with carb cleaner.
Have you checked the fuel line and its inline filter, if it has one? Drained fuel through the petcock into a glass jar and observed whether the fuel flow is even?
