Minarelli Coil Voltage..
Does the Minarelli uses a 6v or is it a 12v?
How does the Spark plug lead connect to the coil and how easy is it to replace just the lead and attach a new cap? Do you just connect the cap on? Sodder it?
Thanks,
Fred
Re: Minarelli Coil Voltage..
The Minarelli V1 is a 6V.
On the models with an external high voltage coil (the little black gizmo that the spark plug wire connects to) the spark plug wire generally screw into it. i.e. there is a brass screw on that the center of the spark plug wire screws into, the spark plug caps generally work the same way.
Thanks Caleb. I believe I have an extra spark plug wire lying arond. I did not try to unscrew it yet. I will try tonight.
Thanks,
Fred
