1980 Sachs Prima
Lonnie Kurowicki /
I am the owner of a 1980 Sachs Prima.
I have zero documentation on this machine.
I can figure most things out but not this one.
There seems to be a part that came loose/lost from the
middle-bottom of the cylinder head. Exhaust/pressure comes out of a small round hole, where the part used to be, only when the clutch cable is depressed.
Two questions.
1. Can someone help me to get a parts diagram for this moped?
2. What is this part that has been lost and how can I get a replacement part?
Re: 1980 Sachs Prima
There is no part missing, exhaust/pressure is supposed to come out of that hole. The clutch cable is also the decompression cable. The pressure releases and makes it easier to start the motor.
Martin Ziskind /
Do you notice trans oil coming up the cable from the clutch to the decompression valve and spilling on the head?
I noticed the side cover has a vent channel which is blocked on my Sachs Sundancer.
