Need help with motomarina sebring not starting...
Matt Manderachi /
Everything on the bike is good to go except whats under the flywheel. First, can someone tell me what everything under there is and what it all does? I want to learn about the electrical system, my weak point(no pun). When I pedal, I get fuel and compression, but no lights and no spark. If anyone can help, i'd greatly appreciate it. Thanks.
Re: Need help with motomarina sebring not starting
Well............the ignition points are under that flywheeland the condensor is too. Replace the spark plug and even the sparkplug wire if need be. File and gap tghe points to .015". Check that the kill switch isn't grounding your spark. don-ohio
Matt Manderachi /
Thanks. I'll see if I can sort things out.
