Vespa Bravo brake cable?
Well, it's finally happened, I'm going blind and/or senile.
How does the front brake cable detach from the brake lever?
If the slotted part on the bottom of the pivot pin threads out, it wouldn't turn for me and I was afraid to shear it off.
Thanks,
Dave
Re: Vespa Bravo brake cable?
Bruce Wilkinson /
My Ciao and Si have a bolt and nut holding the cable on. There is also a small metal 'special shaped washer' that the cable fits in. I need two wenches, one for the bolt and one for the nut to undo and set the cable free. Hope this helps. bruce
