Re: Is Clicking in Transmission normal? AND
Don Ohio /
I'd be draining the tranny fluid and adding the recommended oil with about 4 oz. of kerosene. Then operate the pedals and run it on the stand and operate the pedals a for not more than 5 minutes. Then drain all that out and refill with the proper oil to the proper level. That might free up any sticking `dogs' that have been causing a problem. If it starts working correctly, then drain and refill one more time with the recommended oil. don-ohio
