Is Clicking in Transmission normal? AND
Josh Latour /
Hi All,
I just started riding my 72 garelli and I have noticed that after I stop pedalling ( when the motor is not running ) it sounds sort of like the sound a ratchet makes when it is clicking ( when you are cocking it back for the next tighten or loosen). Is something wrong with it or is this a normal sound??
Also Does any body know the reason why my engine would bog down at low speeds? When I put on the choke while it is bogging it seems to Recover a bit. I can actually speed up quite well when I alternate Choke on Choke off Choke on Choke off etc. as I speed up and as I reach higher speeds the
