Re: suzuki fa 50 help
Don Ohio /
Look for an air inleakage if you know the carb is clean,Ray. Check all connections that could inleak air and also check the base gasket if you can get it running. Do the WD40 spray thing around all connections to check for an air leak. don-ohio
