Re: suzuki fa 50 help
Don Ohio /
Yes....... take the float bowl off, remove the float and needle valve, and start clearing EVERY passage with carb cleaner spray and IF necessary, a fine brass strand of wire from say a 22 gauge `stranded' piece of wire. Make sure there's absolutely NO dirt or anything in that float bowl or on the needle valve or float when you re-assemble it.
Because if you don't, you'll be `stranded' just like the 22 gauge wires! LOL! don-ohio
