CLUTCH PULLER
Edward Edwards /
I have an '84 Puch A.D. 2-speed and the first speed slips badly. Do I need a clutch puller? or will it come off by just removing the 16mm nut thats on the clutch drum. There are two 6mm threaded holes on either side of the nut, is that for a puller? Thanks
Re: CLUTCH PULLER
Probably a lever on either side when pressure is applied equally may remove it? don-ohio (:^)
Re: CLUTCH PULLER
get a puller... it's a variator, right? the tool is worth it
Re: CLUTCH PULLER
Edward Edwards /
It does not have a variator, but I have a puller being sent to me.
