motobecane!!!!
Iiiiiiiii Died /
my motobecane mo-ped will turn over with out a spark plug in it and when i put one in it the engine wont move!!! i have had ppls tell me i needed new rings but not sure im selling it for $100 if i cant fix it or 100 if i can =) jake
Re: motobecane!!!!
Try pulling the decompression cable while pedaling. There should be a lever you pull that opens up a hole in the cylinder head so that you can pedal it over easier. Release it after you get it going, and try to start it.
Re: motobecane!!!!
Also make sure that your piston isn't hitting the spark plug--the plug could be sticking out too far if it's a weird type or if the cylinder head has been milled down, or if you're trying to run it without gaskets maybe.
Re: motobecane!!!!
Iiiiiiiii Died /
hmmmm, not sure whats wrong then =(
Re: motobecane!!!!
Like Matt said.......the decompression cable is likely not actuating. don-ohio
Re: motobecane!!!!
Iiiiiiiii Died /
whats the decopression cable look like??
Re: motobecane!!!!
There's a valve on the top of the cylinder head that a cable is supposed to run to. When the cable is pulled, the valve opens, which makes a hole in the cylinder head that air can flow through (same effect as removing the spark plug, but a smaller hole). That makes it easy to turn the engine over. When the engine is turning, release the cable so that compression is restored and the motor can start.
