PUCH brake light and clutch cable
Tyler Jacobson /
hi guys- two problems my tail light doesnt work but i still have a brake light on my puch maxi whats up do i just need anew bulb? second my clutch cable broke tonight right down where it goes into the engine it is dark out so i havent really been able to look at it is it tricky to set up a new one? thanks again -tyler
Re: PUCH brake light and clutch cable
ok in a maxi there are 2 bulbs
one stays on with lights (running light bulb)
and the other only turns on when you apply the brakes(brake light bulb)
you need a new running light bulb but make sure you get the right one with the same Wattage Amperage and Voltage
i cant help you on your cable though sorry
do you have the one speed, or two speed??
the two speed is a little harder.
Tyler Jacobson /
i have the 2 speed looks like i am gonna need to buy a new cable
