76 Hercules "sluggish"
My '76 Hercules has always been sluggish after riding for a little while, usually only sluggish off the line and tends to almost die whenever I come to a stop. Anything sound serously wrong with it? Hopefully it is something simple or just the engine showing its age. Thanks.
Re: 76 Hercules "sluggish"
Have you cleaned your carburator lately?
clean the carb
as for "almost dieing when i stop" maybe you need to turn your idle up just a bit?
nick
i have a 78 hercules and i know what you mean when you say slugish off the line, mines like that too but mine use to almost die when i came to a stop but all you gotta do is turn the idle screw in the carberator and you will have no more problem, thats what i did and mine runs fine
annother thing to check with the sachs motor is that you have enough tranny fluid. If you get low, the clutch will stick, and die when you stop.
