warped Mikuni on FA50
If anyone with a Mikuni equipped FA50 is having starting problems, you might want to check the flatness of the flange side of the carb. Just by accident I placed the flange side of mine on a true flat surface and discovered that it rocked quite noticably. So, I carefully sanded it to true flat. That should eliminate one possible source of a vacuum leak in the intake system.
