cylinder problem???
Tim Phillips /
Hey everybody! This is my first time posting on this site but I have had a blast looking through all the forums and have learned alot. I have a 1979 Honda PA50II that i'm trying to get on the road. I took it out of the barn this spring and decided I would try to fix it up. It runs pretty good but won't idle. I took the carb off and cleaned it with carb cleaner, blew it out with compressed air and reassembled it following the directions i found from someones (maybe Freds?) post. I also added a fuel filter. It started up fine with the choke on but I still couldn't get it to idle. It just sputters out. So,
-I bought a new plug (theres a nice blue spark)
-checked the compression (it can easily blow my finger off the spark plug hole)
-checked the timing using the thin paper method with the marks on the flywheel (looks good)
-cleaned the points
-cleaned the air filter
-and messed around with the idle and mixture screw on the carb, and it still wouldn't idle. I took apart the carb again and everything is nice and clean. So, I took off the cylinder head and that looked good but in the process I broke one of the bolts that holds it on. To get to it I had to take off the cylinder and this is what I found (attached picture). It looks like the bottom of the cylinder where it fits into the crank has started to wear away or something- it's all black and pitted on the outside. Is this why it won't idle? Have the intake ports enlarged making the engine flood? And I guess my main question is do i need a new one and where could i get one? Sorry for the long post but this is the only thing i can think of that would prevent it from idling correctly and i was hoping someone could help. Thanks!
Tim
  cylinder problem???Topic by: Tim Phillips Tim Phillips 04/28/04 01:54PM
  Re: cylinder problem???Re: 49ccmc Amin 49ccmc Amin 04/28/04 03:46PM
  Re: cylinder problem???Re: Tim Phillips Tim Phillips 04/28/04 04:13PM
