Re: Ciao Issues
Bruce Wilkinson /
Make sure that your rear wheel has not come loose. It's not hard to take the crank off and check for rust on the shaft binding it.
Did you clean off any rust on the inside of the clutch drum surface ? The pads may be worn to the point where they are not grabbing and just sliding. bruce
