Re: Air leak question
Don Ohio /
Bogging and needing choke to run.Hard starting. Whitish plug, and I have even seen a black,sooty plug, I guess from incomplete combustion.
Main thing......DON'T guess. Drip some carb cleaner around the connections to see if rpm changes. Do this before engine gets real hot. If checking engine when hot,drip WD 40 instead. don-ohio
