Re: starting a Yamaha QT50
yeah, and you can even put the nozzle pointing inside the muffler, not all the way, just the flame. That's when it really started smoking.. the outside was already super hot and when I shot flame into the tailpipe the crud really started blowing through.
if you do actually use a mapp torch you probably want to either be careful (heat evenly) or use a propane tank for this job. The mapp was so hot a few times I had to make sure I was spreading the heat-- I think a careless user could burn right through a muffler with a mapp on high.
