Re: FA-50 Vacuum lines
Larry Buyan /
Thanks Neil.
There is a long vacuum line coming from the gas tank area that is just hanging.
There is a vacuum inlet right above the idle and mixture adjust screws that is open.
My makeshift air cleaner does seem to improve thisng. Did you say you are just missing the cover to your air cleaner assembly and fashioned a cover? Or did you relplace the whole air cleaner assembly using the original filter?
Thanks for the help!
