flakey targa turn signals
Reuben Mahaffy /
I've got a 2001 targa, and the turn signals are flaking in and out. I've checked all the wiring that i can see three times, and all the connections seem tight. Is there anything else that could be causing them to sporadically work/not work? Has anyone else had this problem? Any thoughts appreciated.
Re: flakey targa turn signals
John Joedicke /
Check all you signal bulbs, one might be faulty and only making contact once in a while like a car. Change the flasher unit , if it is suspect, just a auto unit.
