Re: trail 90 again now it smokes
Don Ohio /
Probably a leaky float bowl,Shane. gasoline makes whitish smoke,sometimes a little bluish, and even black if air is restricted. Oil is generally blue smoke. Check the carb to see if it's leaking thru. try closing the fuel valve when you stop the bike every time and see if the problem goes away? Okay? don-ohio
