honda pa-50 crankshaft
Ok, here's the deal:
I bought an old cheap honda pa50(II)...the guy almost gave it to me because the crankshaft was broken...
now, it's time for me to fix it, but i got a couple of questions:
Will a honda hobbit (pa-50(I)) crankshaft fit on my pa-50(II)?
What are the differences between the pa50 (I)and (II)?
and what gaz/oil ratio should i use for this engine(the guy didn't know...he was a idiot...)?
thanks all
Re: honda pa-50 crankshaft
Timmy Southpark /
i dont know the difference, but i think there the same. If you need any parts i have most of a motor, and the crank shaft is in good condition. i"ve also got good clutchs and points etc.... Let me know, thanks
Edward Edwards /
The bore & stroke, displacement, compression ratio are the same. the cylinders are machined differently:
PA50-ll exhaust: opens- 65 BBDC / port closes:65 ABDC / scavenge: opens- 47.5 / port closes: 47.5
PA50-l exhaust: opens- 57.5BBDC / port closes: 57.5 ABDC / scavenge: opens 45 / port closes 45.
Yes, either crank will fit. Honda recomends 25:1, but that was 25 years ago. The new oils of today are much better, I use 40:1 synthetic Amsoil thats 3.2oz to the gal.
Guillaume Bergeron /
i would like the entire motor, is it possible for you?, thanks!
