electrics
Kevin Ibbetson /
Found a 1970 motobecane "mobylette" that was running when parked 8 yrs. ago. It looks pretty good overall but has no spark, checked all the usual stuff, plug, high tension lead, ground, electrical connections in the headlight . Next step is to have a look at the magneto under that cover with the big square hole in it. Is that a nut? I've tried the liquid wrench on it and used a strap wrench to secure the cover while I tried to get the "nut" to budge, no deal. Is it clockwise off or the other way? Any suggestions on it's removal or the no spark situation would be helpful, I don't have a manual. Also what is the switch on the handlebar for? On/Off? thanks Kevin
