electrics
Kevin Ibbetson /
Found a 1970 motobecane "mobylette" that was running when parked 8 yrs. ago. It looks pretty good overall but has no spark, checked all the usual stuff, plug, high tension lead, ground, electrical connections in the headlight . Next step is to have a look at the magneto under that cover with the big square hole in it. Is that a nut? I've tried the liquid wrench on it and used a strap wrench to secure the cover while I tried to get the "nut" to budge, no deal. Is it clockwise off or the other way? Any suggestions on it's removal or the no spark situation would be helpful, I don't have a manual. Also what is the switch on the handlebar for? On/Off? thanks Kevin
Re: electrics
Order a shop manual from Mopedwarehouse, and a new condensor. Then you are SET! don-ohio (:^)
Re: electrics
Richard Wisniewski /
dude i had the same problem it was the coil that was toast
rich
Re: electrics
the switch is your engine kill switch
when you want the motor to run set it in the "ON" position
to kill the engine move it to the "OFF" position
the magneto
Dave Chudak /
1/2 inch square drive.. clockwise to loosen (left hand thread)
use a strap wrench... i have yet to accomplish this.. mine is also stuck like fuk.....
go to:
http://www.mopedriders.org/
for the manual. it is under moped repair section.
