smoking exhaust pipe
ok today i rode my ped for about 15 minutes
when i was putting it in the garage i noticed there was a little bit of smoke coming out of the exhaust. (not much sort of the amount that 3-4 birthday candles produce after they are blown out).
anyways
i was just wondering if this is normal.
1980 puch maxi luxe/1 speed/all stock
Re: smoking exhaust pipe
Sure,it's okay.........but maybe the carb is letting some fuel thru before you shut off the fuel valve? Leaky needle valve? don
That seems to be normal. It gets worse when your pipe gets carbon build-up or if you use really crappy oil.
yea it must be the cheap oil i use
ok thanks
Stefan Chivu /
I use 1,5$ cheap oil made by our national petrol producer, is it bad, does 15$ expensive oil make any difference ?
Of course! I had Amsoil Synthetic and switched to Redline which is more expensive. Thanks to Redline, my piston no longer scuffs (if I warm it up) and I got a gain of 1-3 mph and better torque.
Amsoil gave me a noticable HP boost, runs cleaner and no matter how rich I run it only the natural cheap stuff fouls plugs.
Plus, the synth is looser and will flow through an injector better.
No long contrail of 2-stroke smoke with amsoil.
on unmodded bikes it's any oil I can find.
I still prefer my Redline.
